marykw
#1 Posted : Sunday, June 14, 2009 2:19:23 PM(UTC)
marykw
Fridge is on it's highest number but it is still not cold enough, this unit is a full fridge with no freezer
woodchuckie
#2 Posted : Sunday, June 14, 2009 2:47:52 PM(UTC)
woodchuckie
See if the fan inside is running. If it is check defrost timer, defrost heater, defrost thermostat. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Here's a diagram and parts list. null | Model #null | null | SearsPartsDirect.com
marykw
#3 Posted : Sunday, June 14, 2009 3:52:35 PM(UTC)
marykw
Woodchuckie,
Thanks for the speedy reply. I pulled the cover off the evap coil and found it iced up only on the top left side where there is some type of sensor clipped onto the coil. I removed the ice, cleaned & oiled the fan (fan working perfectly) re-installed the cover panel and turned the frig back on. Still seems like the air coming out the top vent is not as cold as it should be.
Frig was working fine until I saw a scorch mark on the evap coil cover where the defrost element is located. Element was near the cover the panel, I pushed it back so there is some clearance to the panel. Since the mark appeared, the interior temp has been slowly rising, coldest it would get today is 52°F.
woodchuckie
#4 Posted : Sunday, June 14, 2009 5:22:23 PM(UTC)
woodchuckie
The entire evaporator coil should be lightly frosted at least. A partial pattern indicates low freon or bad compressor. This requires a qualified tech to service.
Maybe check it again since you have cleaned it all off.
Guest (4)
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 11/18/2018 2:40:04 AM(UTC)
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 1/10/2018 8:28:55 PM(UTC)
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 4/9/2015 1:26:32 PM(UTC)
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 7/14/2013 8:43:21 PM(UTC)
fridge not cold enough, advice needed (Refrigerator & Freezer Repair)
by AcuraNC 6/5/2012 4:43:29 PM(UTC)
by mxrider29 5/30/2012 4:06:47 AM(UTC)
Fridge not cold enough (Refrigerator & Freezer Repair)
by AdamDH 11/24/2011 6:09:02 AM(UTC)
by bigstick7676 9/2/2011 5:57:42 AM(UTC)
GE Profile Artica Fridge Not Cold Enough & Erratic (Refrigerator & Freezer Repair)
by stevedal 6/12/2011 4:46:16 PM(UTC)
Another fridge not cold enough (Refrigerator & Freezer Repair)
by jmath22 12/2/2010 11:30:37 AM(UTC)
integrated fridge not cold enough (Refrigerator & Freezer Repair)
by jayse 6/17/2009 9:45:28 PM(UTC)
Freezer/fridge not cold enough (Refrigerator & Freezer Repair)
by dskalski 2/19/2009 5:34:27 AM(UTC)
Freezer has frost on back wall, fridge not cold enough (Refrigerator & Freezer Repair)
by firfitr247 11/29/2008 11:15:14 AM(UTC)
