volant
#1 Posted : Tuesday, December 25, 2007 3:40:06 PM(UTC)
volant
Hello,
My Whirlpool dishwasher model Quiet Partner III (model GUZ2500XTPB3) does not drain water in normal cycles, water stays inside the machine and goes away when forced by pressing DRAIN.
I checked the following:
1. Dismounted and checked PVC pipes under the sink for proper drainage - found no problem
2. Garbage disposer for proper drainage - all found working well
3. removed the drainage hose from the disposer and used a bucked - machine drained properly during regular cycles.
Perhaps it is important to mention that a month ago I replaced a chopper assembly, which had gotten damaged due to broken glass. A spring, a part of the original chopper got into the grinder and never was recovered. I am curious if that could have impacted, or even damaged the pump.
After replacing the chopper water pressure inside the machine returned to normal and restored relatively good operation of the machine, although my wife keeps complaining about not fully cleaned dishes.
I will greatly appreciate an advice where the problem could be.
Thank you
#2 Posted : Tuesday, December 25, 2007 4:51:30 PM(UTC)
You will need to remove dishwasher, pull the main pump, replace the pump impeller,clean out the motor screen, and also replace the check valve on the right side of the pump chopper. This check valve allows back flushing the screen when the drain pump runs.
volant
#3 Posted : Thursday, December 27, 2007 12:58:30 PM(UTC)
volant
Thank you Richappy for the advise, will order the parts and get it done.
Happy New Year!
V
misterfixall
#4 Posted : Thursday, December 27, 2007 6:33:12 PM(UTC)
misterfixall
richappy. if machine drains well when cancelling, how can it be a mechanical problem?
#5 Posted : Thursday, December 27, 2007 6:45:05 PM(UTC)
Volant probably has two problems not related. Drain problem separate issue, might be control module.
misterfixall
#6 Posted : Thursday, December 27, 2007 7:24:59 PM(UTC)
misterfixall
if machine drains fine when cancelling i can see control module only being problem. no? if not explain please.
#7 Posted : Friday, December 28, 2007 1:17:28 AM(UTC)
Symptoms are control module not sequencing to drain mode.
