rdfaulk53
#1 Posted : Thursday, June 11, 2009 7:29:32 AM(UTC)
rdfaulk53
unit wasn't working so repairman changed board(WR55X10656) freezer seems ok but refrig. side only gets down to 55-58 deg.
woodchuckie
#2 Posted : Thursday, June 11, 2009 12:33:03 PM(UTC)
woodchuckie
For some reason your damper probably is not opening to allow the freezer fan to blow air into the fridge side. Part 426 on diagram 6 is your damper control. Replacement parts for GE GSS20IEMDWW | AppliancePartsPros.com
rdfaulk53
#3 Posted : Monday, June 15, 2009 11:30:57 AM(UTC)
rdfaulk53
repairman didn't read instructions with new board, it called for cutting a wire when used on my model fridg. damper working correct and fridg side stays around 34 degrees.
