twoziggie
#1 Posted : Thursday, June 11, 2009 5:18:32 AM(UTC)
twoziggie
Do I need to remove the drum to replace the belt? If so, how do I do that? Do I go through the top?
twoziggie
#2 Posted : Thursday, June 11, 2009 5:27:17 AM(UTC)
twoziggie
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
sidfink43
#3 Posted : Friday, June 12, 2009 12:23:55 PM(UTC)
sidfink43
No you should not need to remove the drum.
You will need to remove the front of the dryer and the back access panel.
You can slip the belt over the drum, and through the back access panel you can place the belt over the tensioner and then over the motor pulley.
Good luck, let us know if you need any more help.
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
Dryer Belt Replacement (Dryer Repair)
by John Osgood 3/18/2012 10:25:52 AM(UTC)
by lesteree 8/1/2011 5:43:09 PM(UTC)
Frigidaire electric dryer belt replacement (Dryer Repair)
by award 6/21/2010 11:14:23 AM(UTC)
by treedogg 10/8/2009 1:10:32 PM(UTC)
Roper Dryer belt Replacement (Dryer Repair)
by Dubya_tee 9/29/2009 2:13:46 PM(UTC)
Maytag dryer belt replacement (Dryer Repair)
by benb 9/15/2009 12:37:33 PM(UTC)
need photos of ge dryer belt replacement (Dishwasher Repair)
by steeler0ne 8/20/2009 8:49:20 AM(UTC)
Dryer belt replacement (Dryer Repair)
by Donald Marden 7/10/2009 2:55:33 AM(UTC)
by bwilliams 1/4/2009 9:18:53 AM(UTC)
by jbmamaww 11/28/2008 12:28:16 PM(UTC)
Admiral Gas Dryer Belt Replacement (Dryer Repair)
by STEMARHOL 11/8/2008 1:35:17 PM(UTC)
Maytag Dryer Belt Replacement (Dryer Repair)
by Muzzy90G 9/1/2008 6:49:08 AM(UTC)
by lordemmett 5/23/2008 11:07:20 AM(UTC)
by kgnjay 3/4/2008 9:54:25 AM(UTC)
