JRT96
#1 Posted : Tuesday, June 9, 2009 6:56:38 AM(UTC)
JRT96
Architect Series 24.5 cu. ft side by side
Door frame between doors HOT, not warm, to the touch. Any ideas?
woodchuckie
#2 Posted : Tuesday, June 9, 2009 7:00:48 AM(UTC)
woodchuckie
See if the condenser fan is running. It's next to the compressor under the unit accessed from the bottom back. If the fans not running you can place a floor fan at the back until you get it fixed.
See if there is a frost build up on the evaporator coils in the freezer behind the back wall.
