Architect Series 24.5 cu. ft side by side
Door frame between doors HOT, not warm, to the touch. Any ideas?
See if the condenser fan is running. It's next to the compressor under the unit accessed from the bottom back. If the fans not running you can place a floor fan at the back until you get it fixed.
See if there is a frost build up on the evaporator coils in the freezer behind the back wall.
