Ed Kanthack
#1 Posted : Sunday, December 23, 2007 9:17:44 AM(UTC)
Ed Kanthack
Our dishwasher had been running fine but when we tried to run it after filling it with dishes this last time it would not start. It has power because the indicator lights on the selection buttons turn on when we push a run selection. I've tried all of the different selections with no results and also made sure the door was closed and latched securley. Any suggestions?
Ed
TechnicianBrian
#2 Posted : Sunday, December 23, 2007 9:37:27 AM(UTC)
TechnicianBrian
You said the lights are on, when you press the cancel button does it drain? Start a cycle and let it go for at least two minuets. Does it start running. If so, your float switch (the little mushroom looking thing inside the tub) may be stuck in the up position preventing the water valve from turning on. If you don't get a drain operation and the pump never starts, you are probably looking at a control assembly.
Ed Kanthack
#3 Posted : Sunday, December 23, 2007 11:09:17 AM(UTC)
Ed Kanthack
Brian,
Yes the lihgts are on but absoultely nothig happens when we push the selected start button, not even a sound like a solenoid, it's as if the control buttons are not connected to the dishwasher. Could it possibly be the door switch malfunctioning?
misterfixall
#4 Posted : Sunday, December 23, 2007 1:42:05 PM(UTC)
misterfixall
it could be door latch . it could be float problem .it could be water valve ,check to see if your getting 110 volts to water valve when machine is turned on .sometimes caked on detergent get s into float cup. float cup stem may not be seated on switch lever
Ed Kanthack
#5 Posted : Monday, December 24, 2007 7:19:18 AM(UTC)
Ed Kanthack
Since my last e-mail I've checked a few more things. I by passed the door swithch w/ jumpers with no change in results, therefore, I determined that the door switch is not yhr problem. I checked the float switch from both above & below and seems to be working freely. I don't think I'm getting power to the water supply solenoid. There is a solid brown wire and a brown wire w/ a white stripe off each side of the solenoid switch. I don't detect power off either when the dishwasher is in the run mode. Any suggestions?
Ed
TechnicianBrian
#6 Posted : Monday, December 24, 2007 9:04:36 AM(UTC)
TechnicianBrian
The last things to check would be to verify the fill valve is good and it has power going to it. Take off one of the wires to the valve and measure the resistance between the two terminals. It should be around 700 ohms. If it measures open, replace the valve. Plug your meter leads into the two brown wire connectors and start a cycle. You should read 110vac between the two leads. If you are not getting voltage, then your control board is bad.
misterfixall
#7 Posted : Monday, December 24, 2007 10:02:06 AM(UTC)
misterfixall
check to see if your getting 110 volts to float switch . if not unless you have a broken or burned wire to float switch ,you would probably have to reveal wiring in door to control board ,check line +neutral for break or burn. if not problem is board like Gene said ,seasons greetings
#8 Posted : Tuesday, December 25, 2007 1:44:54 AM(UTC)
Per the schematic under the dishwasher, check for power to the control panel and check the thermal fuse also.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
