clothes get caught in the front of the dryer dryer makes no noise other than normal front of the drum sits lower in the front bottom don't know what parts to order is there a kit? or what do you think
It is most likely the rear bearing kit. The rear bearing is worn, and the drum is sit cock eyed. The front the drum, and the belt has to be removed for you to replace the rear bearing kit. Tom ApplianceEducator.com
