Greg H
#1 Posted : Friday, June 5, 2009 5:41:49 PM(UTC)
Greg H
clothes get caught in the front of the dryer
dryer makes no noise other than normal
front of the drum sits lower in the front bottom
don't know what parts to order
is there a kit?
or what do you think
kayakcrzy
#2 Posted : Sunday, June 7, 2009 5:16:26 AM(UTC)
kayakcrzy
It is most likely the rear bearing kit. The rear bearing is worn, and the drum is sit cock eyed. The front the drum, and the belt has to be removed for you to replace the rear bearing kit. Tom ApplianceEducator.com
Greg H
#3 Posted : Sunday, June 7, 2009 6:11:01 PM(UTC)
Greg H
would this be the correct part to order?
is this a fairly simple fix,any special tools?
I take it the bearings are already pressed in for you
shuold I replace the front seals also?
Any help would be great
Thank You
Greg H
[IMG]http://s.sears.com/is/image/Sears/PD_0026_417_5303281153?$pddetailsth$[/IMG]
Part # 53032
Rear bearing kit (including items 5, 6, 12, 13, 14, 18, 32)
Part # 530328115381153
kayakcrzy
#4 Posted : Monday, June 8, 2009 3:21:08 AM(UTC)
kayakcrzy
Thats it. On the front seal, I would take the front off, and view it. Tom ApplianceEducator.com
Greg H
#5 Posted : Monday, June 8, 2009 9:55:46 AM(UTC)
Greg H
Thank You
Greg
