jreynolds
#1 Posted : Saturday, December 22, 2007 1:28:43 PM(UTC)
jreynolds
My mother in law has a Maytag washer, less than 4-5yrs old, that started making a loud grinding/howling noise during a wash/spin cycle. The next load it filled, and made the noise on spin cycle. If you turn to agitate, spin, etc, the drum will spin and the loud noise begins.
I assume it is the pump. I tried pulling the belt off the motor, with no change in the noise. Is there a way to isolate the pump from the motor without removing it? The model number is SAV205DAWW, serial number of 14221499GL
jreynolds
#2 Posted : Wednesday, December 26, 2007 6:06:51 PM(UTC)
jreynolds
replaced the pump, works fine.
kawfeeman
#3 Posted : Thursday, December 27, 2007 1:05:00 AM(UTC)
kawfeeman
check the belt also .... make sure that the noise is definitely gone as these machines are prone to problems with bearings.
