kgundi
#1 Posted : Friday, June 5, 2009 7:39:39 AM(UTC)
kgundi
Washer fills and agitates just fine, but then stops when rinse cycle is supposed to start. Does not drain or spin; just stops dead. Could this be just a bad lid switch? How do I bypass it to check? Could it be the timer? BTW, same result in all wash cycles.
Thanks for your help.
#2 Posted : Friday, June 5, 2009 4:14:11 PM(UTC)
Most likely the problem is a bad lid switch. You have to open the control panel to access its plug and remove the washer cabinet to replace it.
- New lid switch and step by step instructions on how to replace the lid switch: Part number: AP3100003
Whirlpool Washer Stops Mid Cycle (Washer Repair)
by cfphillips 9/3/2010 11:01:15 AM(UTC)
