wevans70
#1 Posted : Tuesday, June 2, 2009 7:33:20 PM(UTC)
wevans70
I have a Roper model number REX5634KQ1. Problem with it is that it was working one day and now wont. I checked the breaker and that didn't work. Im out of ideas at the moment, also It seems like the unit doesn't get any juice at all. I have no way to check at the moment to see if there is juice at the outlet.
#2 Posted : Wednesday, June 3, 2009 5:40:52 AM(UTC)
Replacement parts for WHIRLPOOL REX5634KQ1 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Does the light in the drum come on?
If not odds are high that you have a house wiring problem and not a machine problem, unless f curse it did not work before this problem.
Did you turn the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. This can give the symptom you describe. Best to check it with a meter. L1 to L2 should be 240 volts and both L1 and L2 to Neutral should be 120 volts.
Next open the door and manually actuate the door switch while trying to start it. Could be it is just not being activated by the door. Best to check it with a meter.
Next would be the thermal fuse. The one on the blower assembly.
Unplug the unit, remove one wire from it and check it with a meter, should be 0 ohms.
OR
Try the jiggery pokery method
Unplug the unit, short the two wires going to the fuse together, tape them up so they cannot short to anything else, plug the unit in and give it a try.
If blown replace ASAP as this is a critical safety device.
Also if blown clean/check the blower wheel and your vent system.
wevans70
#3 Posted : Wednesday, June 3, 2009 1:33:59 PM(UTC)
wevans70
Thank you for the info. I tried ( Try the jiggery pokery method
Also if blown clean/check the blower wheel and your vent system.) this meathod and now my dryer works. Thank-you
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
