2 Pages12>
mkmcdani
#1 Posted : Monday, June 1, 2009 8:14:51 AM(UTC)
mkmcdani
(Not sure how old our washer is- it came with our house~)
It fills and drains fine, but apparently isn't spinning/agitating. I tried it on several different cycles thinking maybe it would work on another one, but it isn't working at all- it doesn't make any sounds or anything. Any suggestions?
#2 Posted : Monday, June 1, 2009 8:49:00 AM(UTC)
Make sure the lid switch is working, should make a click when you close the lid.
mkmcdani
#3 Posted : Monday, June 1, 2009 8:53:15 AM(UTC)
mkmcdani
Sounds like the lid switch is working fine.
#4 Posted : Monday, June 1, 2009 12:56:16 PM(UTC)
Make sure there is power at the outlet, rather unusual problem unless a connector came loose.
mkmcdani
#5 Posted : Monday, June 1, 2009 1:36:27 PM(UTC)
mkmcdani
There don't appear to be any issues with power- the outlet is good and it is getting power. Is there something else I should be looking at??
#6 Posted : Monday, June 1, 2009 2:17:55 PM(UTC)
If it drains, the motor works, is that true.
mkmcdani
#7 Posted : Monday, June 1, 2009 3:21:10 PM(UTC)
mkmcdani
Yup. It's draining fine. It's just not wringing the clothes dry at all. They're soaking wet when the cycle finishes.
#8 Posted : Tuesday, June 2, 2009 2:47:28 AM(UTC)
Pull the pump and motor and turn the tranny coupler clockwise and counterclockwise and post your results.
mkmcdani
#9 Posted : Tuesday, June 2, 2009 9:53:56 AM(UTC)
mkmcdani
It's hard to turn clockwise- takes a lot of pressure, doesn't really turn counterclockwise at all. Is it supposed to be so difficult to turn? It only rotates the agitator & basket at the same time- the agitator doesn't turn independent of the basket. Is it supposed to be like that?
#10 Posted : Tuesday, June 2, 2009 11:03:44 AM(UTC)
Seems like a bad tranny. Pull it out and check.
Guest (8)
2 Pages12>
