Richard Mastroberte
#1 Posted : Sunday, May 31, 2009 7:24:20 AM(UTC)
Richard Mastroberte
Dishwasher is not drying glasses or getting hot enough on Sanitize or Pots cycles. Hot water heater is on 135 degrees. Could it be that the heating coil at the bottom of the washer is burned?
#2 Posted : Sunday, May 31, 2009 7:55:48 AM(UTC)
Replacement parts for FRG PLDB999CC0 | AppliancePartsPros.com
Here is a wiring diagram / tech sheet
http://manuals.frigidaire.com/p...df/Kinston/154444501.pdf
Yes it could be the heating element.
Remove the wire from one side of it and measure it with a meter.
Should be around 15 ohms.
Could also be the thermostat.
Should be 0 ohms at room temperature.
Could be the control board.
Measure voltage P5 to W. One side of the HiLimit Thermostat to the far side of the Heating Element. Should be 120 volts when cycle is telling the unit to heat.
Bosch Dishwasher Not Heating (Dishwasher Repair)
by jesseinpdx 12/8/2021 1:35:27 PM(UTC)
Whirlpool Model WD720PADM3 Dishwasher not heating (Dishwasher Repair)
by DSomers 1/24/2021 1:12:17 PM(UTC)
GE dishwasher not heating.... gdf620hgj2bb (Dishwasher Repair)
by Keeber 1/12/2019 8:32:51 AM(UTC)
Kenmore dishwasher not heating (Dishwasher Repair)
by Blanka182@yahoo.com 1/14/2016 2:10:42 AM(UTC)
Dishwasher not heating after replacing Heating element and thermostat (Dishwasher Repair)
by smbegg 1/4/2016 11:47:09 AM(UTC)
Whirlpool Dishwasher not heating (Dishwasher Repair)
by jml927 6/15/2015 1:17:57 PM(UTC)
Dishwasher not heating/drying (Dishwasher Repair)
by dbearce 7/29/2014 7:08:35 AM(UTC)
Dishwasher Not heating (Dishwasher Repair)
by Kenpilot 12/4/2013 9:38:28 AM(UTC)
Bosch dishwasher not heating up! (Dishwasher Repair)
by babybuddha 6/20/2013 4:24:52 AM(UTC)
Kenmore dishwasher not heating water or drying (Dishwasher Repair)
by abqsteve 1/2/2013 5:18:17 PM(UTC)
Bosch Dishwasher not heating water (Dishwasher Repair)
by MIKEGUS 7/2/2012 7:32:28 AM(UTC)
Dishwasher Not Heating Water (Dishwasher Repair)
by pec329 12/16/2011 5:09:55 AM(UTC)
by misschief 8/12/2011 4:06:16 AM(UTC)
Whirlpool Dishwasher not Heating plus clean light flash (Dishwasher Repair)
by jasone 2/28/2011 8:15:08 AM(UTC)
Frigidaire Dishwasher not heating (Dishwasher Repair)
by planemad1 1/13/2011 1:40:57 PM(UTC)
