flgentrys
#1 Posted : Sunday, May 31, 2009 7:23:16 AM(UTC)
flgentrys
Our Frigidaire 4000 series dishwasher has no power. There is power to the plug but nothing at the control panel. Any ideas? Is there a hidden reset switch inside? This thing just went out of warranty, typical huh?
#2 Posted : Sunday, May 31, 2009 7:59:51 AM(UTC)
flgentrys
#3 Posted : Monday, June 1, 2009 3:48:10 AM(UTC)
flgentrys
I took the door panel off and looked at all the parts but do not know how to tell if anything is defective. Is there a way to test the door switch, or do I just replace it and hope for the best?
#4 Posted : Monday, June 1, 2009 4:20:23 AM(UTC)
No, you have to test them.
One way would be to short the wires to each switch together, tape them up so they cannot short to anything else and give it a try.
OR
Use a meter
If doing the short tape a towel or something in front of the unit just in case the pump comes on you do not want to get wet.
Also check that the unit is getting power, you will need a meter for this.
KitchenAid Dishwasher - "new" control board = dead dishwasher (Dishwasher Repair)
by Bobo827 8/9/2013 10:59:38 AM(UTC)
by Millard Dunn 3/10/2011 1:23:30 PM(UTC)
Help! Flashing Lights-dead Dishwasher?-signed Frustrated Mom (Dishwasher Repair)
by manualplease 7/11/2010 12:46:53 PM(UTC)
