phayburnsr
#1 Posted : Thursday, December 20, 2007 12:34:08 PM(UTC)
phayburnsr
Dishwasher makes loud vibrating noise at the beginning of the cycle and several times during cycle and at cycle end.
#2 Posted : Thursday, December 20, 2007 3:39:31 PM(UTC)
Check if the noise is coming from the water valve under the sink when the dishwasher is filling with water. Very possible a vibrating washer.
okbobcats
#3 Posted : Thursday, December 20, 2007 6:26:41 PM(UTC)
okbobcats
Or it also could be the pump out pump. Is you pull off the kick panel in front you can see and even touch the discharge pump. Its on the left front side . When its making this noise put a little pressure on the pump. If noise stops then its your pump.
kawfeeman
#4 Posted : Friday, December 21, 2007 6:18:39 AM(UTC)
kawfeeman
i have also seem some some food stuffs get stuck in circ pump impeller and cause a little vibration to sometimes...
phayburnsr
#5 Posted : Saturday, December 22, 2007 5:09:00 AM(UTC)
phayburnsr
The noise doesn't occur during the fill cycle. Seems to be only when discharging water. The machine is only 14 mo. old. I suspect the noise is coming from the pump, probably something stuck, but I don't know how to fix. Do I get at the pump from inside or underneath the machine?
#6 Posted: : Saturday, December 22, 2007 8:07:26 AM(UTC)
If the dishwasher is only 14 months old then it's still under the manufacturer warranty.
Do not do anything and call the Bosch.
