Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My top load Maytag (purchased 6/14/22) washer locked and the water sensor light is flashing. I reset the fuse and got the lock open. I removed the 2 towels and blanket, but the sensor light is still blinking. It will not start a new load and if I try to anything it will lock again. The items were soaked. Apparently it did not finish spinning. How do I reset? Edited by user Tuesday, May 28, 2024 6:21:40 AM(UTC)
| Reason: Give more information
Rank: Guest
I have a Maytag direct drive front loader that locked the door and did not drain. I tried cleaning the trap first but did not help. I replaced the water pump and now it comes on but just buzzes and the door is still locked. I have now ordered the air dome trap but running out of options. Any sugges?
Rank: Guest
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
If the model number of your appliance could be provided, it will allow the most accurate information to be presented.
