tech_58
#1 Posted : Saturday, May 30, 2009 1:44:05 PM(UTC)
tech_58
Q1: What would cause oven not to heat up? :confused:
The oven was working but "FAIL" :D (after fixing R.F. burner) this morning. :))
Two clicking sounds (from solenoids marked as BAKE and outer Broil) after pressing "BAKE then START", but NO HEAT in oven after 30 sec.
"TOD" was working, it is "close-loop-circuit". In addition, I bypass "TOD" and tied two plug-connectors together and test it. The oven does not heat up.
Thank for your help.
tech_58
#2 Posted : Saturday, May 30, 2009 6:28:24 PM(UTC)
tech_58
The problem was traced to loose wire(s) in the DLB relay.
The oven was re-tested and "working :)" after re-connecting loose wire(s).
