Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello I hope you can help me. I have GE Profile PB930SF1SS range. Recently some of the panel lights come on randomly with the system making a few beep sounds. Nothing comes on as far as heating is concerned. After a few seconds they turn back off. Otherwise the cooktop and oven works fine. Any suggestions?
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
The touchpad and the oven control would need to be checked for any indications of a short. If there is not an indicator, there may likely be an internal issue in the touchpad that's causing this issue.
Rank: Guest
It seems to have stopped now. "odd" So if it happens again should I wait for something to stop working or should I replace the touchpad if it is a possible DYI project?
Replacing a component while it is in a working state would be a preference decision rather than something that would be a recommendation.
