madmanandy27
#1 Posted : Thursday, March 21, 2024 1:26:26 PM(UTC)
madmanandy27
United Kingdom
Hey guys, I am Really hoping someone can help me as this is driving me nuts. I have this heat pump dryer (samsung DV90K6000CX) it switches off after between a minute and 5 minutes with no error codes at all. I have completely stripped the machine and even taken out the whole heat exchanger unit and cleaned it until its immaculate. I have cleaned the moisture sensor bars etc and cleaned the whole machine inside and outside (filters etc) checked every connection and have tested the cooling fan thermisters etc. Just a bit of extra info it also switches off in timed mode. The drum runs great, the pump seems to be working as i can hear it and i can hear the pump on the heat echanger unit switching on. Does anyone have any advice please? TIA.
WilliamM/APP Team
#2 Posted : Saturday, March 23, 2024 6:55:33 AM(UTC)
WilliamM/APP Team
Groups: Moderators, APP Team, Registered
United States
Was thanked: 14 time(s) in 14 post(s)
As this is an appliance not domestic to the US, limited information is available to us. However, based on the information provided, it sounds like there is a control failure.
thanks 1 user thanked WilliamM/APP Team for this useful post.
madmanandy27 on 3/27/2024(UTC)
madmanandy27
#3 Posted : Wednesday, March 27, 2024 12:11:27 PM(UTC)
madmanandy27
United Kingdom
thanks for that i have ordered a new control board.
i will provide an update after i have replaced it just for reference.
Edited by user Wednesday, March 27, 2024 12:12:09 PM(UTC)  | Reason: Not specified
madmanandy27
#4 Posted : Wednesday, April 3, 2024 5:40:37 AM(UTC)
madmanandy27
United Kingdom
(UPDATE) Hey guys, i thought i would update this post just in case of the event anyone ends up in the same sitution. i tested everything and cleaned everything and it still did it. so i ordered a new pcb control board as it was the only thing that was left. replaced and right away there was a difference when closing the door it made a beep but with the old one it didnt. it must still have been sensing the door being closed or it wouldnt start. So something had went wrong on the PCB. I hope this helps someone in the future.
Guest (4)
