gml
#1 Posted : Tuesday, May 21, 2013 4:35:27 PM(UTC)
gml
The washer would not start despite showing power to the control panel. I replaced the control panel but now all the panel lights flash in synchrony constantly and the washer does not start. we pulled the plug and left it sit for 48 hours but the same thing is happening. Is there a ground somewhere? How to I fix? thanks
fairbank56
#2 Posted : Tuesday, May 21, 2013 5:37:55 PM(UTC)
fairbank56
Groups: Expert
Did you transfer the model select connector from the old control board to the new one? It's the connector with a single jumper wire on it.
Eric
gml
#3 Posted : Thursday, May 23, 2013 1:33:08 PM(UTC)
gml
Eric
I do not know what that is. Where on the old control board is it located? A wiring diagram would help. We connected all wires that needed to be unplugged from the old control board to the new. thanks
fairbank56
#4 Posted : Thursday, May 23, 2013 3:07:26 PM(UTC)
fairbank56
Groups: Expert
Next to the large transformer on the old circuit board there should be a connector with one or two jumper wires on it. This must be transfered to the new board. It is the model selector plug that tells the processor which model washer you have. The board can be used with different model washers.
Eric
waterpapa
#5 Posted : Sunday, December 8, 2013 8:25:21 AM(UTC)
waterpapa
Moving the plug from the old control panel to the new one fixed it, but mine had
a total of 2 wires or four ends plugged into the jumper.
Thanks so much for your assistance. The wife is happy again!!!!
Guest
#6 Posted : Friday, July 21, 2023 12:54:43 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Mine didn’t have a jumper on the old board
Guest
#7 Posted : Friday, July 21, 2023 12:56:50 PM(UTC)
Guest
Rank: Guest
Groups:
United States
I need a picture of where next to the large transformer is
