DIY_Again!
#1 Posted : 2 years ago
DIY_Again!
United States
Hello, all!
My question is: How can I test the transmission on my machine to determine whether I need an entire new transmission or if I can just get away with a neutral drain kit?
I have a Kenmore Model 80 machine that recently was making a noise. Based on advice from this posting I replaced the basket drive assembly and clutch. But, that didn't fix the issue.
There is also new behavior I don't believe existed before: When the spin cycle first starts, it doesn't drain the water prior to spinning; it spins and drains at the same time. However, it also makes loud grinding and banging noises while doing so. The noise is so bad, I stop the spin cycle rather than let it finish to prevent any further potential damage.
From what I can tell, all signs point to the transmission. Is there any way to determine whether I can get away with a neutral drain rebuild kit or if the transmission is basically shot? I appreciate any advice.
Thanks!
[EDIT] I forgot to mention, it seems to agitate as expected without issue.
Model 110.26842694
Brand Sears Kenmore
Age More than 15 years
Transmission 3360629
Edited by user 2 years ago  | Reason: Add relevant info.
