AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Less than two year old top load Maytag Washer Lid Hinge broken
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Same problem, left side plastic broken at the hinge - Bought April 2019 at Lowes - Model # MVWB765FW - I have an extended warranty purchased through Lowe's but if new lids are not available what is the solution?
Rank: Guest
Bravo Maytag lid is broken at both hinge sites. I purchased it from Lowes Feb of 2020. Afraid that it will happen again if I purchased a new one. I am caught between a rock and a hard place. Glass top lids are abad design.Very disappointing! gdY7
Groups: Expert
Rank: Guest
I purchased mine 2.5 yrs ago. 6 months ago left corner of the lid cracked. Then a month ago the right corner cracked now I can’t even close the lid. from what I’m reading This is a major problem and we should have a class action suit against them. I hate to replace it to have to keep replacing it because it’s gonna keep cracking. I’m actually thinking about just getting a new machine and it won’t be a Maytag.
Rank: Guest
Any updates on this issue? Ours broke for the second time!
Rank: Guest
Rank: Guest
Rank: Guest
Rank: Guest
Same problem. 2019 purchase. Left hinge breaking plastic since 2021 Continues to crumble and Maytag says no complains filed. No recall. $130 repairman service charge and part $345. This is a 3 yo washer.
Rank: Guest
Same issue, bought washer from Lowe’s in 2019. Left back corner of lid cracked/crumbled after a year. Luckily I had an extended warranty. Same thing is happening again in 2023. There must be some defect with this lid.
Washer Repair
