The dryer flips the circuit breaker after running a few minutes. We have changed the thermostat on the dryer and also changed the circuit breaker and still have the same problem. What could be the culprit?
Originally Posted by: Gene  Gene, Thank you for writing. We discovered the dryer has 3 thermostats and we only replaced one. One is still avaliable and the third one is no longer available. So out dryer huntng we went--we found a brand new Maytag with some scratch and dents for less than $280! God is good:)
