Replacement parts for WHIRLPOOL LER4634BQ1 | AppliancePartsPros.comHere is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdfTry flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next check the thermal fuse and thermostats with a meter.
