3 Pages<123>
Guest
#11 Posted : Wednesday, April 20, 2022 3:03:45 PM(UTC)
Guest
Rank: Guest
Groups:
United States
The arm lifter in the back of mine was frozen in place. Hair dryer 30 seconds= done!!
Guest
#12 Posted : Sunday, August 21, 2022 1:28:19 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Originally Posted by: Ewan007 Go to Quoted Post
I ran into this problem (no cubes, only crushed) after cleaning my ice bucket.
Turns out the metal arm sticking out of the back needed to be above the solenoid arm. I reached under the bucket when pushing it in and manually pulled the white solenoid arm down to ensure the metal arm pushed in above it.
Problem solved only took 15 seconds. HTH
Thanks for these videos and parts! The wifie is getting mad at me because I keep fixing her old appliances and she's not getting new ones. :D
Oh my gosh. I was ready to call a repairman after trying other fixes. This was the one I needed! Thank you for sharing
Guest
#13 Posted : Sunday, December 4, 2022 9:03:34 AM(UTC)
Guest
Rank: Guest
Groups:
United States
It worked!!! Such an easy fix, I have been just not using my ice maker!
Guest
#14 Posted : Sunday, December 11, 2022 7:09:30 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Originally Posted by: Guest Go to Quoted Post
I had the same issue, noticed ice was frozen at where the bucket inserted and prevented the metal rod fully engaged the solenoid elevator which moves it up for ice cubes. Removed the ice blockage and voila! ice cubes are dispensing. Thanks.
Thanks worked great
Guest
#15 Posted : Saturday, December 24, 2022 11:14:14 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Cut the power by either unplugging or shutting the breaker off for 1 minute turn power back on and hit cube which is under the power off light on mine
Worked for me
Guest
#16 Posted : Sunday, March 26, 2023 4:42:28 PM(UTC)
Guest
Rank: Guest
Groups:
United States
@Ewan007
You genius! Thank you! Worked for me, too!
Guest
#17 Posted : Sunday, March 26, 2023 4:43:39 PM(UTC)
Guest
Rank: Guest
Groups:
United States
@Ewan007
Guest
#18 Posted : Friday, April 7, 2023 6:07:58 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Thanks fixed it up nicely!
Guest
#19 Posted : Monday, April 10, 2023 3:58:04 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Ewan007: turns out this was our problem as well. We tried to fix it. We now only get ice cubes. I believe we broke it when we were pushing it down with a long metal skewer and pushing the ice back in. Our model is from 2020. It’s ok. We’d rather have cubed than crushed anyway
Guest
#20 Posted : Saturday, August 5, 2023 2:51:29 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Thank you for this! It fixed this issue for me
3 Pages<123>
