AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE top loader won't maintain spin after replacing clutch today
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have an older GE toploader washing machine from 2001 (WBSE2090A0WW) that a few weeks back started making a horrible sound when agitating or spinning. It actually performed fine, just loud as heck, a harsh clunk-clunk roaring/grinding sound. After perusing various forums for advice I did the following:
New tub bearing (no improvement). Replaced lower transmission bearing (very difficult and the original bearing was leaking and would click-click when rotating so it was definitely due for a replacement)
After that it was still making the harsh clunk-clunk sound, but again would wash my clothes normally. Huh. Ran a few loads and all was well, but just that horrible sound.
Then I thought it might be the clutch. Replacement clutch came in today and after installation it's amazingly quiet!!! The horrible sound is gone!!
But now it won't spin. It tries, it will start spinning for a couple of seconds, building up speed, but then it stop spinning.
I thought it was the switch on the left side of the tub with the air hose. I could pull it off the tub and blow into it and I could hear the switch click behind the control panel, so I don't think that's it.
When it's off and I try and rotate the drum by hand counterclockwise it is pretty difficult, takes some oomph. But I don't know what is normal.
Could it be I got a bad clutch? How could I test the clutch to see?
Rank: Guest
Ok, this is the original poster.
I put the old wanky clutch back on. The horrible noise is back, BUT it does go into spin cycle.
Looks like I bought a bad clutch. I got it off eBay since no appliance parts stores around here had it in stock.
The box it came in has the manufacturers name on it. Vialu. I wouldn't consider them a good supplier. Hope I can get a refund from the eBay seller.
Washer Repair
