may25
#1 Posted : Tuesday, May 26, 2009 3:15:28 AM(UTC)
may25
Maytag washer model LAT9206BAE will agitate and will pump water but can not get enough speed when trying to spin. Also will eat up belt. Will turn free clockwise but not counter clockwise. I thought it was the belt slipping and put a new on on but it ate it too.
Aliens1
#2 Posted : Thursday, May 28, 2009 10:43:06 AM(UTC)
Aliens1
I have the same problem, Does your machine make a grinding noise?...
or maybe the brake release in no good.
The transmission broke down..on mine.. If I can get some feed back on my , i will contact you to see if I can help you out...
Let me checjk your model # and pull out the service manual from the experts...
may25
#3 Posted : Thursday, May 28, 2009 5:45:11 PM(UTC)
may25
The machine does not make a grinding noise. I removed the transmission cover looking for any damage, and everything looks ok. I can spin the transmission drive pulley clockwise and it turns freely, when I turn it counter-clockwise, the brake assembly engages and the transmission is hard to turn by hand, and the belt will slip when I put the washer in the spin cycle. I don't know how to tell if the brake assembly may be the problem or the transmission.
Aliens1
#4 Posted : Thursday, May 28, 2009 9:31:10 PM(UTC)
Aliens1
If your transmission is ok, check your cluch.
Sorry i'll keep on looking..
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
