I have Samsung Model WF45H6300AW/A2 washer. The rotor was separating from the center hub. I replaced it and when doing the spin test, it cycles back and forth really fast and then set the 3E3 code. The drum is tight no bearing problem and the drum rotates freely. When putting it in service mode I can count the drum rotation as I turn it by hand. Anything else I should check?
