TommyK1
#1 Posted : Sunday, July 24, 2022 11:40:31 AM(UTC)
TommyK1
United States
Recently replaced limit switch at upper left of drum heater. Had to remove drum to effect this repair. Drum quit working. Belt tensioner Pulley had dislodged itself, lying in bottom of upper cabinet. Belt beginning to show wear. When repositioned on pulley shaft, it turned roughly. I steel wooled shaft to get clean up roughness, then put lithium grease on shaft, reinstalled pulley and belt. Turned on the dryer. Worked fine for a bit then launched the pulley. 3 times the pulley dislodged itself. Pulley Shaft seems to be cocked to left, as viewed from the back of the cabinet. HELP!
Edited by user Sunday, July 24, 2022 11:52:04 AM(UTC)  | Reason: Not specified
ThatGuy
#2 Posted : Sunday, July 24, 2022 12:34:47 PM(UTC)
ThatGuy
Groups: Expert
United States
I'd say you probably need a new idler pulley and a new belt. Parts 23 and 25.
https://www.appliancepar...ctrolux-ffle1011mw2.html
TommyK1
#3 Posted : Sunday, July 24, 2022 12:43:46 PM(UTC)
TommyK1
United States
Pulley seems to be in good repair, and spins well after cleaning the shaft and lubing. There may be an alignment problem. The idler arm seems to be 'loose', and not tracking well in relation to the drive pulley on the motor. The drawings do not show how this arm attaches to the motor bracket.
TommyK1
#4 Posted : Sunday, July 24, 2022 12:52:41 PM(UTC)
TommyK1
United States
I may have answered my own question. Do you have any suggestions for removing the tensioner arm?
TommyK1
#5 Posted : Friday, July 29, 2022 5:50:52 PM(UTC)
TommyK1
United States
Well, I ordered the Idler Assembly and Belt. I am concerned that I was charged too much sales tax.
WED7500VW belt replacement (no belt tensioner) (Dryer Repair)
by dafoster78 5/12/2014 1:56:12 PM(UTC)
Frigidaire washer belt tensioner (Washer Repair)
by Jason H 11/2/2009 2:06:11 PM(UTC)
