Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
30 yr old GE Profile fridge. (TFH24PRSMWW)
Not cooling well; seems to shut on/off periodically. Evap fan and condenser fan are working well. Coils are clean. Compressor relay is good.
Suspect compressor thermal protector (WR8X114). This is a "Klixon" style thermal protector Mfg PN: 4TM427NFBYY-61
Seems no one makes the "-61" with 2 spade connectors. The only one available is a "-53" with single connector.
Any wiring modification available on using the "-53"?
Thanks!
