Rank: Administration
Checking various dishwasher components for continuity allows you to identify a failed component. For example, you can test your dishwasher water valve solenoid, float switch, and other dishwasher parts. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
My dishwasher's problems occurs when I select a cycle on the front of the dishwasher - nothing happens (even after I replaced the touchpad on the door of the dishwasher).
I've read the article posted online, but it does not tell me how to test the continuity for the touchpad on the front of the dishwasher, nor the continuity for the control board on the inside of the dishwasher.
Joined: 4/27/2020(UTC) Posts: 0  Location: Connecticut
I am having the same problem - no lights on control panel - replaced door latch sensor - still no lights. I also need instructions on how to check for continuity on the control board or possibly a new defective control panel or any other component this forum suggests.
Thanks,
Milty
This link goes to a 404 file not found error. Please fix your sticky post. Really could use this help. Thanks! Also… Please remove the two spam posts on this thread? Edited by user Wednesday, May 4, 2022 8:26:31 AM(UTC)
| Reason: Not specified
404 file not found error! Originally Posted by: Admin / APP Team  Checking various dishwasher components for continuity allows you to identify a failed component. For example, you can test your dishwasher water valve solenoid, float switch, and other dishwasher parts. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter |
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
