Dryer timer buzzer won't stop unless door was opened or turned to new dry cycle. Replaced the timer but same issue, buzzer won't stop. What next?
Originally Posted by: gmanks  Dryer timer buzzer won't stop unless door was opened or turned to new dry cycle. Replaced the timer but same issue, buzzer won't stop. What next? Turns out it was the Start push button switch. Dryer would start as soon as you turned the timer to a new cycle. Contacts were stuck, so cleaned them up and that did the trick. Will need to get a new one in the near future.
I'm glad you were able to diagnose and fix the problem. Good job!
Thank you for the feed back.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have the same problem with my Kenmore.
I need to know what contacts he is talking about?
Groups: Expert
Hes talking about the contacts inside the start switch being 'welded' together. I've seen it happen a couple of times.
