gmanks
#1 Posted : Thursday, September 9, 2010 1:45:18 PM(UTC)
gmanks
Dryer timer buzzer won't stop unless door was opened or turned to new dry cycle. Replaced the timer but same issue, buzzer won't stop. What next?
#2 Posted : Thursday, September 9, 2010 7:14:31 PM(UTC)
Sounds like the buzzer is the culprit.
- The buzzer Part number: AP3019850
gmanks
#3 Posted : Friday, September 10, 2010 1:34:40 PM(UTC)
gmanks
Turns out it was the Start push button switch. Dryer would start as soon as you turned the timer to a new cycle. Contacts were stuck, so cleaned them up and that did the trick. Will need to get a new one in the near future.
#4 Posted : Friday, September 10, 2010 3:36:34 PM(UTC)
I'm glad you were able to diagnose and fix the problem. Good job!
Thank you for the feed back.
Guest
#5 Posted : Sunday, April 24, 2022 8:15:37 AM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
I have the same problem with my Kenmore.
I need to know what contacts he is talking about?
ThatGuy
#6 Posted : Sunday, April 24, 2022 9:22:32 AM(UTC)
ThatGuy
Groups: Expert
United States
Hes talking about the contacts inside the start switch being 'welded' together. I've seen it happen a couple of times.
