pcarlson
#1 Posted : Sunday, December 26, 2021 5:17:03 AM(UTC)
pcarlson
Washer makes slight grinding/squeaking noise when agitating, although it still agitates fine, clothes are being washed. I removed washplate and the gear underneath seems fine, gear teeth still look intact.
Drains fine, pump sounds good.
Clothes are soaking wet when done. I don’t think it went through the spin cycle. When it does, it makes a loud banging noise.
pcarlson
#2 Posted : Sunday, December 26, 2021 5:56:26 AM(UTC)
pcarlson
Update…I pulled my washer out and there’s a puddle of oil/grease underneath. Something is leaking.
jkernsjr
#3 Posted : Thursday, January 13, 2022 1:08:02 PM(UTC)
jkernsjr
United States
I have a different model Whirlpool but had similar issues. Finding the oil/grease led me to understanding that I was going to have to replace the bearings and tub seal. There are kits you can but and many YouTube videos that show how to do this. If you have a spare afternoon and a bit of mechanical skills as well as socket wrench you should be able to do it yourself for a few hundred dollars.
