I am getting a faint gas smell from my oven when it is off. The manual says I may need to adjust the oven burner air shuttle. Would this really be causing the smell when the oven is off?
Quote:Would [needing to adjust the oven burner air shutter] really be causing the smell when the oven is off? No it wouldn't, only while in use. You may have a gas leak somewhere. You should have a licensed gas appliance service technician look into it ASAP! :eek: JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
