Joined: 7/26/2021(UTC) Posts: 0  Location: British Columbia Thanks: 1 times
Is it worth the risk to buy an upright freezer with this problem? Is there a likely culprit and would it be a relatively simple fix? It is a 20 cu ft upright with model number WZF79R20DW0G? Seller says "Keeps throwing itself into defrost mode. Don’t know how to fix it" https://scontent.fyvr2-1...61718097&oe=612636FC
Groups: Expert
It really depends on what the freezer is doing. It could be the compressor is failing to start or it could be a problem with the electronic control. They are not cheap. I'd look for something else. Unless the price is $0 and you want something to work on. https://www.appliancepar...w11382526-ap6893037.html
 1 user thanked ThatGuy for this useful post.
