Most likely the problem is a bad key pad which is a part of the control panel but there is a small chance for the control board to be bad as well. Check the key pad operation as described on the page 1 of the tech sheet (attached to the reply). If you will need the correct part number for the control panel, post the color of it. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2500XTPS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comGene.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
When I shut my dishwasher door the "light"wash and heated dry buttons are lit. I am able to change light wash to normal, but not able to shut off heated dry, which I don't use. After I wash a load on normal, it reverts back to light wash. Any ideas??
