After a power outage my Whirlpool range (model GS773LXSS0) is displaying "E1 F1" error code. I unplugged it for about 15-20 minutes and when I plugged it back in the same error code came on. I've read that replacing the ERC (Part # AP4355979)is the remedy, but before purchasing this piece I wanted to know:1. Is this the likely problem? 2. How easy is it to replace?I appreciate any help,Greg
Originally Posted by: Gregud1  After a power outage my Whirlpool range (model GS773LXSS0) is displaying "E1 F1" error code. I unplugged it for about 15-20 minutes and when I plugged it back in the same error code came on. I've read that replacing the ERC (Part # AP4355979)is the remedy, but before purchasing this piece I wanted to know:1. Is this the likely problem? 2. How easy is it to replace?I appreciate any help,Greg Greg, According to the Tech sheet and Whirlpool instructions, the suggested correction is to replace the control board. The control board Part number: AP4355979
Thanks for your help Gene. Much appreciated.
You are welcome Greg. Keep us posted.
Got the part tonight, switched it out (very simple to do) and it works like new. Thanks again.
You are welcome Greg. I'm glad you were able to fix it.
I'm in Canada his happened to our stove how much does it cost for this part??? Originally Posted by: Gene  Greg, According to the Tech sheet and Whirlpool instructions, the suggested correction is to replace the control board. The control board Part number: AP4355979
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a e1-f1 code on a whirlpool electric range/stove MDL# GY395LXGQ1
Rank: Guest
