2 Pages<12
#11 Posted : Tuesday, July 20, 2010 12:33:18 PM(UTC)
Originally Posted by: madtowncookie Go to Quoted Post
I have the same exact problem mulean had on the same model oven (RBD275PDB6), and I want to order parts to try to fix it.
Mulean mentions that he replaced parts AP3008987 and AP3110028.
Apparently there is another fuse for this oven - AP3133249 - do you suggest that I replace this part as well?
Thanks for any help!
This thermal fuse is for the lower oven only.
madtowncookie
#12 Posted : Tuesday, July 20, 2010 1:24:05 PM(UTC)
madtowncookie
Thanks Gene - would you suggest that I order both the parts that mulean replaced (thermostat and fuse) ... or just 3110028 for starters?
#13 Posted : Tuesday, July 20, 2010 3:16:25 PM(UTC)
If the upper oven is not heating and the display is blank, then you need them both. If the problem is just the upper oven not heating, then the thermostat Part number: AP3008987
should be enough.
If the display is blank and you do not know if the oven will heat, order both the fuse Part number: AP3110028
and the thermostat.
thomsonlafosse
#14 Posted : Saturday, March 8, 2014 6:35:42 AM(UTC)
thomsonlafosse
We have a single oven whirlpool and had the same problem with the self clean. Electronic controls are dead, door won't open. Can't find fuses? If they are inside the door, that doesn;t help us...door is locked.
Aagh!
AppNovice
#15 Posted : Saturday, November 1, 2014 10:54:03 PM(UTC)
AppNovice
I have Whirlpool Double wall oven GBD307 which stopped working after self clean cycle. There was no display and the upper door oven door was locked. After reading many posts on internet including at this site, I purchased and replaced both the thermal fuses parts from appliancepartspros - AP3885687 Thermal overload (for upper oven) and AP3110028 Thermal Fuse (for control panel). After changing both the fuse when I turned the circuit breaker... there is burning smell coming from the control panel. Needless to say, there is still no display and door is locked. :mad:
There was no smell coming from control panel with circuit breaker ON before changing the fuses.
Any Pros suggestion is welcome on what could have gone wrong. or how to fix the next issue.
wb6otg
#16 Posted : Sunday, May 30, 2021 1:08:21 PM(UTC)
wb6otg
United States
The link above that explains how to open the door no longer works. Can anyone tell me how to do it?
Guest
#17 Posted : Sunday, June 27, 2021 9:29:24 AM(UTC)
Guest
Rank: Guest
United States
Did you ever get an answer? What did you do?
We have same problem with single Whirlpool wall oven.
We can’t get to any controls/ fuses, etc. because door is locked, and any fix for opening door, does not work: no latch to hook on to.
Thanks,
Sara
iSaraTex
#18 Posted : Sunday, June 27, 2021 9:39:52 AM(UTC)
iSaraTex
United States
You can find the complete instructions how to open the control panel and the oven door in one of previous posts: http://forum.appliancepartspros...ning-cycle-rbd306pd.html
Post the complete model number and we'll help you with the right part numbers.
Gene, that link no longer works, thx, Sara[
Guest
#19 Posted : Monday, February 7, 2022 1:15:32 PM(UTC)
Guest
Rank: Guest
United States
GE double oven stopped working during self cleaning mode, door locked, nothing on the control panel. Checked power, have power to the control panet. Replaced control panel still nothing Any suggestions?
2 Pages<12
