just_phil
#1 Posted : Thursday, June 24, 2021 9:21:44 PM(UTC)
just_phil
United States
Hi, I have a Sub-Zero 550 that needed a new evaporator fan motor. Got a new motor from an authorized dealer and put it in. Right away I notice that the motor is spinning in the other direction. The original motor spins clockwise when looking at the fan, the new one is spinning counter-clockwise. The wires are all connected correctly, plus it wouldn't matter on an AC motor anyway. So does anyone know what's going on? Was there a change in the specs? Also, the fan is shaped in such a way that it would be more efficient blowing downwards, and now it's blowing upwards. The part number is 4200170.
Thanks in advance!
DoctorG
#2 Posted : Thursday, August 5, 2021 7:35:09 PM(UTC)
DoctorG
United States
Thanks in advance!
Mine has been replaced recently and it's very noisy, but it's definitely blowing downwards.
Did you resolve your problem? May I ask you where you sourced your part from? Is the noise level the same as before?
Thanks!
