willis1000
#1 Posted : Wednesday, May 27, 2009 6:04:10 AM(UTC)
willis1000
After dissasembling burner I found the smaller (inner) burner to be broken.
Is this normal occurence or did something elese cause problem? In other words should I just replace the burner or should I also replacing a switch etc??
Willis
#2 Posted : Wednesday, May 27, 2009 5:38:25 PM(UTC)
Willis,
Such situation is pretty normal and I do not think you have to replace the switch unless it was any other signs. Replace the heating element it. and hopefully the problem would gone.
- The part number for the dual element is AP2027786
Here are the breakdown diagrams and Replacement parts for GE JBP78WB4WW | AppliancePartsPros.com
kitchen aid cooktop dual burner problem (Oven Repair (including Ranges and Cooktops))
by danjoc 4/12/2010 5:53:13 PM(UTC)
GE Spectra Dual Burner problem (Oven Repair (including Ranges and Cooktops))
by willis1000 5/26/2009 12:46:05 PM(UTC)
Whirlpool Accubake dual burner problem (Oven Repair (including Ranges and Cooktops))
by jwilso 2/3/2009 5:06:05 AM(UTC)
by danrum 11/14/2008 11:37:30 AM(UTC)
