I have a front load frigidaire dryer. It started coming up with an error code of E68 on the digital display. It happenned five times this morning. Please let me know what this code is. Thanks Ed B
I Have The Same Error Code E68 And Would Like To Know It Is And How To Fix It.
In order to provide most accurate advice we need the complete model number of your dryers.
my model no. is LEQ7000ES0 i get the error code E68.what do i have to do to fix the problem.
Joined: 11/1/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Frigidaire dryer model AEQ7000ESO error code E68 (stuck button). Sometimes a ‘stuck button’ code really is a stuck button. I took the circuit board off the front panel. On the back side of the front panel, each button has 3 short plastic posts, 2 on one side and 1 on the other. The center part moves to push a longer piece that contacts the circuit board. When I push the top of a front stadium-shaped button, the center plastic piece moves too far, touches the short post, and sticks (maybe due to age). When I push the bottom of the front button, the plastic piece goes far enough to contact the circuit board and not far enough to touch the short post. To prevent a stuck button, we now press the bottom of the front buttons. So far so good. NOTE: I tried to attach a couple photos. Couldn't get it to work. Edited by user Sunday, November 1, 2020 1:04:16 PM(UTC)
| Reason: Not specified
