EdBe
#1 Posted : Tuesday, July 15, 2008 11:02:33 AM(UTC)
EdBe
I have a front load frigidaire dryer. It started coming up with an error code of E68 on the digital display. It happenned five times this morning. Please let me know what this code is.
Ed B
cats
#2 Posted : Sunday, July 26, 2009 2:33:01 PM(UTC)
cats
I Have The Same Error Code E68 And Would Like To Know It Is And How To Fix It.
#3 Posted : Monday, July 27, 2009 12:25:11 PM(UTC)
In order to provide most accurate advice we need the complete model number of your dryers.
cats
#4 Posted : Tuesday, July 28, 2009 9:09:25 AM(UTC)
cats
my model no. is LEQ7000ES0 i get the error code E68.what do i have to do to fix the problem.
#5 Posted : Tuesday, July 28, 2009 7:28:27 PM(UTC)
Perform the troubleshooting as instructed in the Tech sheet.
Here are the breakdown diagrams and Replacement parts for FRG LEQ7000ES0 | AppliancePartsPros.com
Bob102
#6 Posted : Sunday, November 1, 2020 1:01:55 PM(UTC)
Bob102
United States
Frigidaire dryer model AEQ7000ESO error code E68 (stuck button). Sometimes a ‘stuck button’ code really is a stuck button. I took the circuit board off the front panel. On the back side of the front panel, each button has 3 short plastic posts, 2 on one side and 1 on the other. The center part moves to push a longer piece that contacts the circuit board. When I push the top of a front stadium-shaped button, the center plastic piece moves too far, touches the short post, and sticks (maybe due to age). When I push the bottom of the front button, the plastic piece goes far enough to contact the circuit board and not far enough to touch the short post. To prevent a stuck button, we now press the bottom of the front buttons. So far so good.
NOTE: I tried to attach a couple photos. Couldn't get it to work.
Edited by user Sunday, November 1, 2020 1:04:16 PM(UTC)  | Reason: Not specified
