tsmith25
#1 Posted : Saturday, October 31, 2020 10:18:53 AM(UTC)
tsmith25
United States
My dryer works properly on the timed dry cycle, however it just keeps running on the auto cycles, the dryer does heat up, just stay on.
This is what I have done so far.
I have purchased certified used Timer and Control Board. I tested the timer by removing the black wire on (I think X) and tested continuity between X and T with the knob turned between the Wrinkle care and off and there was continuity.
I removed the cycling thermostat and tested for continuity and it does, I even put it on a skillet around 175-200 degrees and within about 20 seconds the continuity was lost.
I have removed the moisture sensing bars and cleaned them toughly with vinegar
I also took the drum out and tested I both safety switches in the back and they had continuity (just tested at room temp)
After all of this the dryer still will not turn of on the auto cycle. I may not be testing properly, so any input would be helpful.
