FDN09
#1 Posted : Wednesday, April 22, 2020 5:58:56 AM(UTC)
FDN09
United States
Oven control panel and surrounding area gets hot and condensation accumulates in the control panel when cooking above 300 and it shut down the oven. None of the buttons works. I have to reset the breaker for the oven to work again. I've noticed the cooling fan are not running when I start the oven which I suspect could be the problem. Cooling fans have a connector with 3 wires: two white/tripe wires on the sides and a black wire in the middle. When I apply 120V to the two White/trip wires, the fans turn on. But if I apply the voltage to White/trip - Black, I get nothing. I do have 120V coming of the ERC to the fan. Any idea?
wilhelmsmith
#2 Posted : Wednesday, May 13, 2020 9:55:15 PM(UTC)
wilhelmsmith
American Samoa
Air Canada is the banner transporter and the biggest carrier of Canada by armada size and travelers conveyed. The carrier, established in 1937, gives planned and contract air transport for travelers and loads to 207 destinations around the world. It is an establishing individual from the Star Alliance. Air Canada's corporate central command is in Montreal, Quebec, while its biggest center point is at Toronto Pearson International Airport. The aircraft's provincial help is Air Canada Express.
Air Canada Reservations
