When I press the start button it flashes along with 3 beeps. From what I have found this is a door issue problem. I replaced the door switch, but I have the same issue. I disconnected the power, waited overnight to see if the error would stop. It did not. Not sure what my next step is. Any assistance would be appreciated. Thanks, Mitchell
Rank:: Member
I also have the same problem with starting my GE dishwasher. Quit starting up after power outage. Tried resetting it by leaving it off for an hour, but when I would try to start the cycle, instrument panel would acknowledge everything I wanted to do but when I pushed the start, I waited a few seconds for it to start but then I would get the 3 beeps all over again. Becoming frustrated not knowing which "PART" to replace. If anyone has help, please don't hesitate to offer. Thanks, Tim
