Hello All,
I am new here to this forum but could really use some help. I have a Samsung Electric Dryer, Model #DV43H5000EW/A3 that runs but will not produce any heat. I did some internet research and it seems a common issue is a bad element. I bought and installed a new element, hi limit and thermal cut off and I'm experiencing the same results.
The dryer runs good, no unusual noises, no error codes. There is a red blinking waffle/grid type icon that flashes when I power the unit on. I can't recall if this has always been there or if this could be trying to tell me something.
I have checked all vent hoses, dryer is free of lint, can't find any clogs anywhere.
I have been hit pretty hard by the Hurricane and my money is pretty tight right now and that is why I would like to do this myself, if possible.
Does anyone have a suggestion for what could be causing this?
Thank you very much for any help you could offer.
Any solution ever given for this? I'm having the same issue but with an electric dryer. Thank you.
Following. I am having the same problem with a Samsung Electric dryer that is barely over 3 years old.
