I have GE Dryer (DBVH512EFWW) that intermittently will not engage the tumble motor -- usually after a few loads have been run. It appears to be some kind of overheating but I'm not clear how to resolve it. When this last occurred, I entered diagnostic mode and ran all diagnostics as per the service manual https://www.applianceblo...als/31-9136_GEFDryer.pdfThe results were as follows: t01 = 02 t02 = E00 t03 = 045 t04 = EPP t05 = all LEDs light t06 = beep t07 = Drum does not rotate, 073 temperature displayed t08 = Drum does not rotate, 123 temperature displayed t09 = 2.00 t10 = HI I have replaced the thermostat, but this did not resolve the problem: https://www.appliancepar...-shuts-off-too-soon.htmlI'd welcome any advice on how to resolve the issue.
