fordsbyjay
#1 Posted : Tuesday, February 5, 2019 10:36:25 AM(UTC)
fordsbyjay
United States
I am visiting my daughter and she is having problems with her dishwasher not drying. The dishes are drenched like nothing is heating at all.
The first thing I checked was the high limit thermostat. It had continuity when cold and clicks open when hot. Idk at what temp but hot in a pan.
Second I checked the heating element for continuity. It was bad so I replaced it (I also checked the new one before install to make it sure it was ok). I ran the dishwasher again and the bottom dishes are dry but the top ones are still drenched. I opened the door as soon as it was finished and it was hardly warm inside not hot and steamy like every other dishwasher I have owned.
I also turned off the breaker for 15 minutes.
I also checked the hot water supply and it is about 18 seconds till I can't hold my hand under it.
It also has drying liquid in it.
My question is how do I test the power to the heating element or at the main control board during the drying cycle?
Edited by user Tuesday, February 5, 2019 10:42:30 AM(UTC)  | Reason: Not specified
